uipathctl reference guide
uipathctl resource report
Generate resource utilization report on cluster in Automation Suite.
Description​
Generates a report on the resources in the cluster.
uipathctl resource report [flags]
Examples​
# Generates a resource report
Options​
  -h, --help            help for report
      --output output   The output of the report. Can be one of: json, minreqsgo (default json)
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
