uipathctl reference guide
uipathctl config orchestrator upload
Upload files, NLog extensions, or secure store plugins to storage.
Description​
Upload files, nlog extensions or secure store plugins to storage
uipathctl config orchestrator upload [flags]
Examples​
# Upload files to storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory
# Upload nlog extensions to storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory
# Upload secure store plugins to storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory
# Upload files to external storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory --is-external-storage
# Upload nlog extensions to external storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory --is-external-storage
# Upload secure store plugins to external storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory --is-external-storage
Options​
  -h, --help                                   help for upload
      --is-external-storage                    flag whether the storage is external
      --namespace string                       The namespace where UiPath Automation Suite is deployed (default "uipath")
      --nlog-extensions-directory string       location of the nlog extensions on the local disk
      --securestore-plugins-directory string   location of the securestore plugins on the local disk
      --storage-directory string               location of the storage directory on the local disk
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
