uipathctl reference guide
uipathctl service
Service management subcommands for managing services.
Description​
Manage service-related commands.
uipathctl service [flags]
Options​
  -h, --help   help for service
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
