uipathctl reference guide
uipathctl rke2 upgrade
Upgrade embedded Kubernetes in Automation Suite on Linux.
Description​
Upgrade embedded.
uipathctl rke2 upgrade [flags]
Options​
  -h, --help            help for upgrade
      --skip-pre-reqs   Skips pre-requisite checks during install
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
