uipathctl reference guide
uipathctl cluster migration export
Export the cluster state from source cluster to a local directory in Automation Suite.
Description​
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
  1. Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
  2. The input and version files are used to configure the migration process.
uipathctl cluster migration export [flags]
Examples​
# Export the cluster state from source cluster to a local directory
uipathctl cluster migration export --output-dir /tmp/cluster-source
Options​
  -h, --help                help for export
      --namespace string    The namespace where UiPath Automation Suite is deployed (default "uipath")
      --output-dir string   path to output directory
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
