uipathctl reference guide
uipathctl snapshot backup disable
Disable periodical snapshot backup in Automation Suite.
Description​
Disable the periodical snapshot backup of the cluster.
uipathctl snapshot backup disable [flags]
Options​
  -h, --help            help for disable
  -p, --prefix string   This will prefix the names of all the snapshot backups with the given string.
                     (default "snapshot")
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
