uipathctl reference guide
uipathctl rke2 generate-registries
Generate RKE2 registries configuration based on cluster config in Automation Suite on Linux.
Description​
Generate the RKE2 registries configuration based on the cluster configuration found at PATH.
uipathctl rke2 generate-registries PATH [flags]
Options​
      --ca-cert-path string          path to copy the registry CA certificate to
      --current-config-path string   path of the current registries configuration
  -h, --help
  -h, --help
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
