uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl rke2 prereq run
Run RKE2-specific prerequisite checks in Automation Suite on Linux.
Runs the RKE2 specific prerequisite checks.
uipathctl rke2 prereq run PATH [flags]
Options
-h, --help help for run
-m, --machines strings Comma separated IP address / hostnames of all the machines to run connectivity check against
--node-type string Possible values [server|agent|task-mining|asrobots|gpu]. Defaults to server (default "server")
--only string If set, limits the scope of the command to a specific check (e.g., 'rpm')
-o, --output output Output format. One of [json,yaml,text]. Defaults to text (default text)
-v, --verbose verbose output
--versions string path to versions file
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
--upgrade include upgrade-related checks
