uipathctl reference guide
uipathctl cluster migration
Cluster subcommands for managing cluster state migration in Automation Suite.
Description​
Manage the cluster state migration, such as object store, secrets, or Insights data migration.
uipathctl cluster migration [flags]
Examples​
# Run migration between two clusters
uipathctl cluster migration run input-target.json --target-kubeconfig kubeconfig.target --kubeconfig kubeconfig.source
# Runs migration of cluster state in offline cluster
uipathctl cluster migration export --kubeconfig kubeconfig.source
# Run cluster import
uipathctl cluster migration import --kubeconfig kubeconfig.target
Options​
  -h, --help   help for migration
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
