uipathctl reference guide
uipathctl manifest get-revision
Get content of latest or specified revision in Automation Suite.
Description​
Get the content of the latest revision or of the revision with the specified version.
The output is in JSON format.
uipathctl manifest get-revision [flags]
Examples​
# Get the revision with the specified version number from the cluster
uipathctl manifest get-revision --version number
# Get the latest revision from the cluster
# Get the latest revision from the cluster identified by the current context in the kubeconfig file
uipathctl manifest get-revision input.json/cluster_config.json --kubeconfig cluster.kubeconfig
Options​
  -h, --help               help for get-revision
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --version int        specify revision version
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
