uipathctl reference guide
uipathctl snapshot backup enable
Enable periodical snapshot backup with schedule in Automation Suite.
Description​
Enable the periodical snapshot backup of the cluster.
uipathctl snapshot backup enable [flags]
Options​
  -h, --help               help for enable
  -p, --prefix string      This will prefix the names of all the snapshot backups with the given string.
                       This is only used if you wish to enable schedule backup.
                     The default value is snapshot
                        (default "snapshot")
  -r, --retention string   Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
                       Default value of 168h.
                        (default "168h")
      --schedule string    Unix cron expression for schedule
                       this is only required if you wish to enable schedule backup.
                     Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
                        (default "*/45 * * * *")
                        (default "168h")
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
