uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl prereq run
Run prerequisite checks to validate installation success in Automation Suite.
Runs the prerequisite checks to validate that the installation would succeed.
uipathctl prereq run PATH [flags]
Examples
# Runs all the prerequisite checks
uipathctl prereq run input.json/cluster_config.json --versions versions.json
# Runs the prerequisite checks on any available node without pinning to a specific node
uipathctl prereq run input.json/cluster_config.json --node any --versions versions.json
# Runs the prerequisite checks only on a specific node
uipathctl prereq run input.json/cluster_config.json --node <node-name> --versions versions.json
Options
-h, --help help for run
--node string node on which to run the per-node prerequisite checks. one of [all, any, <node-name>] (default all)
-o, --output output output format. one of [json,yaml,text] (default text)
-v, --verbose verbose output
--versions string path to versions file
--list-options list all available options for the included and excluded flags
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
--upgrade include upgrade-related checks
