uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
Copy infra images to agent directory on all nodes in Automation Suite on Linux.
Copy the infra images to the agent directory on all nodes.
uipathctl internal rke2 hydrate-agent-dir [flags]
Options
--concurrency int Number of agent nodes copy images concurrently (default 3)
-h, --help help for hydrate-agent-dir
--images-filepath string ImageList filePath
--is-insecure Is registry hosted over insecure/http server
--name string System upgrade controller plan name
--password string Password for source registry
--src-registry-url string Source registry URL for copying images
--tmp-path string Path to copy uipathcore and Imagelist (default "/tmp")
--username string Username for source registry
--versions string Artifacts file server URL (default "upgrade-server-service.kube-system.svc.cluster.local:80")
