uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl manifest list-revisions
List past configuration files applied to cluster in Automation Suite.
List past input.json/cluster_config.json files applied to the cluster.
The output is always in tabular format. By default, the list is sorted by version number.
uipathctl manifest list-revisions [flags]
Examples
# List revisions of the current cluster
# List revisions of the cluster identified by the current context in the kubeconfig file
uipathctl manifest list-revisions --kubeconfig cluster.kubeconfig
Options
-h, --help help for list-revisions
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")
--show-command if true, prints the commands corresponding to stored revisions as the last column
