uipathctl reference guide
uipathctl reference documentation
Controls the UiPath Automation Suite deployment.
Description​
Controls the UiPath® Automation Suite deployment.
uipathctl [flags]
uipathctl [flags]
Options​
  -h, --help                help for uipathctl
  • Description​
  • Options​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
