uipathctl reference guide
uipathctl rke2
RKE2 configuration subcommands for managing specific configurations.
Description​
Manage the rke2 specific configurations
uipathctl rke2 [flags]
Options​
  -h, --help   help for rke2
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
