uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
Seed in-cluster registry from temporary registry in Automation Suite on Linux.
Seed the in-cluster docker-registry from the temporary registry. By default, the seed will be performed for all registry pods.
To seed a specific registry pod, use --cluster-registries argument with required pods's IP. To reduce hydration time, you can increase the number of worker thread by passing --num-worker argument. Please ensure all registry pods are in Running state before performing hydration.
uipathctl rke2 registry hydrate-registry [flags]
Examples
# Seed all registry pods using configuration found in cluster_config.json
uipathctl rke2 registry hydrate-registry cluster_config.json
# Seed specific registry pod having ip 10.42.0.157
uipathctl rke2 registry hydrate-registry cluster_config.json --cluster-registries 10.42.0.157
# Seed all registry pods with 12 worker count
uipathctl rke2 registry hydrate-registry cluster_config.json --num-worker 12
Options
--cluster-registries strings List of cluster-registries ip along with port, if not mentioned then all the registry pods considered
-h, --help help for hydrate-registry
--num-worker int Number of workers to seed images in parallel (default 3)
