uipathctl reference guide
uipathctl config saml-certificates update
Update future SAML certificate with PFX and key in Automation Suite.
Description​
Update the future SAML certificate providing the pfx and key as arguments.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config saml-certificates update [flags]
Examples​
# Update the saml certificate with the provided pfx file path and password from the cluster
uipathctl identity update-saml-certificate --cert server.pfx --password password
# Update the saml certificate with the provided pfx file path and password from the cluster identified by the current context in the kubeconfig file
uipathctl identity update-saml-certificate --cert server.pfx --password password --kubeconfig cluster.kubeconfig
Options​
      --cert string        path to certificate
  -h, --help               help for update
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --password string    password for pfx file
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
