uipathctl reference guide
uipathctl config products scale-up
Scale up the cluster with optional high availability in Automation Suite.
Description​
Scale-up the cluster.
uipathctl config products scale-up [flags]
Options​
      --ha     Scaling up the cluster with HA
  -h, --help   help for scale-up
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
