uipathctl reference guide
uipathctl snapshot restore logs
Show logs for restore operation in Automation Suite.
Description​
Show the logs for the restore operation. NAME denotes the name of the restore you want to show the logs for.
uipathctl snapshot restore logs NAME [flags]
Options​
  -h, --help   help for logs
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
