uipathctl reference guide
uipathctl snapshot backup
Snapshot backup subcommands for backing up cluster.
Description​
Back up the snapshot of Automation Suite.
uipathctl snapshot backup [flags]
Options​
  -h, --help   help for backup
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
