OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl manifest diff
Load the configuration provided as argument and compare it to the configuration found live in the cluster.
Without any flags, only the manifest is compared,whereas cluster-wide configurations and dependencies are ignored.
The output is always YAML. By default, the diff command available in your path runs with the -u (unified diff), -N(treat absent files as empty), and --color (color output). Add the --no-color flag to disable color output.
uipathctl manifest diff PATH [flags]uipathctl manifest diff PATH [flags]
Examples
        # Diff manifest found in input.json
        uipathctl manifest diff input.json
        # Diff manifest found in input.json, using the configuration found in cluster.kubeconfig
        uipathctl manifest diff input.json --kubeconfig cluster.kubeconfig
        # Diff manifest found in input.json, including cluster wide configurations and dependencies
        uipathctl manifest diff input.json --include-dependencies --include-config
Options
  -h, --help                   help for diff
--include-config         include cluster wide config in the diff
--include-dependencies   include dependencies in the diff
--no-color               disable color output  -h, --help                   help for diff
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
