uipathctl reference guide
uipathctl registry cleanup
Remove unused images from docker registry after upgrade in Automation Suite.
Description​
Remove unused images from docker registry after upgrade.
uipathctl registry cleanup [flags]
Options​
      --dry-run              if true, just print the list of tags to be deleted, without performing the cleanup
  -h, --help                 help for cleanup
      --images-list string   path to image list json file, containing images to be cleaned up. Example file format: { "cleanup-list": [ "aicenter/python39:23.10.0-rc4", "registry.io/uipath/uipathcore:local" ] }
      --manifest string      path to docker image manifest
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
