uipathctl reference guide
uipathctl config additional-ca-certificates
Additional CA certificate subcommands for managing CA certificates.
Description​
Manage additional CA certificates.
uipathctl config additional-ca-certificates [flags]
Options​
  -h, --help   help for additional-ca-certificates
Options inherited from parent commands​
      --versions string     optional path to versions file)
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
