uipathctl reference guide
uipathctl config token-signing-certificates
Token signing certificate subcommands for managing signing certificates.
Description​
Manage Token Signing certificates.
uipathctl config token-signing-certificates [flags]
Options​
  -h, --help   help for token-signing-certificates
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
