uipathctl reference guide
Last updated Nov 11, 2025
uipathctl config saml-certificates get
Get the current SAML certificate observed in the cluster in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config saml-certificates get [flags]uipathctl config saml-certificates get [flags]
Examples
# Get the current saml certificate from the cluster
# Get the current saml certificate from the cluster with additional certificate information
uipathctl config saml-certificates get --show-details
# Get the current saml certificate from the cluster identified by the current context in the kubeconfig file
uipathctl config saml-certificates get --kubeconfig cluster.kubeconfig# Get the current saml certificate from the cluster
Options
-h, --help               help for get
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
    --show-details       if true, additional saml certificate information will be printed  -h, --help               help for get
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
