uipathctl reference guide
uipathctl config telemetry set
Set cluster telemetry in Automation Suite.
Description​
Set the cluster telemetry.
uipathctl config telemetry set [flags]
Options​
  -d, --debug     Run in debug mode
      --enabled   Enable or disable telemetry
  -h, --help      help for set
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
