uipathctl reference guide
uipathctl config add-host-admin
Add host administrator with specified credentials in Automation Suite.
Description​
Add a host admin and specify their credentials.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config add-host-admin [flags]
Examples​
# Add host admin with the provided username and password in cluster
uipathctl config add-host-admin --username newadmin --password password
# Add host admin with the provided username, password and email in cluster
uipathctl config add-host-admin --username newadmin --email email --password password
# Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
uipathctl config add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig
Options​
  -e, --email string       host admin email
  -h, --help               help for add-host-admin
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
  -p, --password string    host admin password
  -u, --username string    host admin username
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
