uipathctl reference guide
uipathctl config orchestrator update-encryption-key
Update Orchestrator encryption key in Automation Suite.
Description​
Update the Orchestrator encryption key.
uipathctl config orchestrator update-encryption-key [flags]
Examples​
uipathctl config orchestrator update-encryption-key --new-key <key>
uipathctl config orchestrator update-encryption-key --new-key <key> --namespace <namespace>
Options​
  -h, --help               help for update-encryption-key
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
      --new-key string     The encryption key to update
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
