uipathctl reference guide
uipathctl health check
Check deployment health using Kubernetes API without cluster mutation in Automation Suite.
Description​
Check the health of the deployment using the Kubernetes API. This command only performs tests that do not mutate the cluster.
uipathctl health check [flags]
Examples​
# Get the health of the cluster
Options​
  -h, --help               help for check
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
  -v, --verbose            verbose output
Options inherited from parent commands​
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
  -o, --output output       output format. one of [json,yaml,text,junit] (default text)
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
