uipathctl reference guide
uipathctl config argocd
ArgoCD subcommands for managing ArgoCD configuration in Automation Suite.
Description​
Manage ArgoCD configuration.
Options​
  -h, --help   help for argocd
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
