uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
Manage RKE2 FQDN update and restart RKE2 service on nodes in Automation Suite on Linux.
Manage the RKE2 FQDN update and restart the RKE2 server on all the nodes including update offline registry.
uipathctl rke2 update-fqdn -i|--input PATH [flags]
Examples
# rke2 fqdn update from cluster config, restart rke2 service on all the nodes in cluster
uipathctl rke2 update-fqdn -i|--input "/opt/UiPathAutomationSuite/UiPath_Installer/cluster_config.json"
Options
--concurrency int Number of agent nodes fqdn update concurrently (default 3)
-h, --help help for fqdn update
-i, --input string Installer artifact directory path (default "/opt/UiPathAutomationSuite/ UiPath_Installer/cluster_config.json")
