uipathctl reference guide
uipathctl resource constraint-report
Generate report of policy violations in cluster in Automation Suite.
Description​
Generates a report of the violations in the cluster.
uipathctl resource constraint-report [flags]
Examples​
# Generates a report of all the policy violations in a cluster
Options​
      --build-id string            Pipeline buildID
      --check-for-new-violations   Checks for new violations
      --client-id string           ADX clientID
      --client-secret string       ADX clientSecret
      --clusterURL string          ADX url
  -h, --help                       help for constraint-report
      --tenant-id string           ADS tenantID
      --whitelistFilePath string   path of whitelisted violations
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
