uipathctl reference guide
uipathctl config kubeconfig set
Update alternative cluster Kubernetes context in Automation Suite.
Description​
Update the alternative cluster Kubernetes context.
uipathctl config kubeconfig set [flags]
Options​
  -d, --debug           Run in debug mode
  -h, --help            help for set
  -m, --multisite       Update the kubeconfig context to connect with the alternative cluster in multisite setup.
      --secret string   Base64 encoded kubeconfig to update the context
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
