- Overview
- About uipathctl
- uipathctl reference documentation
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
Command-line tool for managing Automation Suite deployments on EKS/AKS, OpenShift, and Linux.
uipathctl is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS, Automation Suite on OpenShift, and Automation Suite on Linux.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
Note, however, that not all commands referenced in this guide are suitable for all Automation Suite flavors. If certain commands are exclusive to one Automation Suite flavor, they should be marked accordingly.
It is important to be aware of the specific naming conventions we employ for the Automation Suite configuration file:
input.json- Automation Suite on EKS/AKS and Automation Suite on OpenShiftcluster_config.json- Automation Suite on Linux
For more information, including a complete list of uipathctl operations, see the uipathctl reference documentation.
You can install uipathctl on the Linux, macOS, and Windows platforms.
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
