uipathctl reference guide
uipathctl registry validate
Validate docker registry in Automation Suite.
Description​
Validate the docker registry.
uipathctl registry validate [flags]
Options​
  -h, --help              help for validate
      --manifest string   path to docker image manifest
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
