uipathctl reference guide
uipathctl version
Print current client version information.
Description​
Print the current client version information.
uipathctl version [flags]
Options​
  -h, --help   help for version
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
