uipathctl reference guide
uipathctl rke2 gpu
Enable or disable GPU on cluster in Automation Suite on Linux.
Description​
Enable/Disable the GPU on the cluster.
uipathctl rke2 gpu [flags]
Options​
      --enable   Enable/Disable gpu on the cluster.
  -h, --help     help for gpu
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
