uipathctl reference guide
Last updated Feb 28, 2026
uipathctl cluster migration run
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
  1. Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
  2. The input and version files are used to configure the migration process.
uipathctl cluster migration run [PATH] [flags]
Examples
        # Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
        uipathctl cluster migration run input.json/cluster_config.json --versions versions.json --target-kubeconfig <path> --target-kubecontext <context>
Options
  -h, --help                       help for run
      --skip-outbound-data         skip outbound data migration
      --skip-pre-reqs              skip prerequisite checks for data migration
      --target-context string      name of kubeconfig context to use for target cluster
      --target-kubeconfig string   target cluster kubectl configuration file
      --versions string            path to versions file
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
