uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
Reference for the uipathctl cluster migration run command, which executes a full cluster migration from a source to a target cluster in Automation Suite.
The following command executes the cluster migration from a source cluster to a target cluster.
There are two stages of the migration process:
- Kubernetes objects are migrated from the source cluster, followed by the installation on the target cluster.
- The input and version files are used to configure the migration process.
uipathctl cluster migration run [PATH] [flags]
Examples
# Migrate from source cluster to target cluster, using input.json/cluster_config.json as the target cluster configuration
uipathctl cluster migration run input.json/cluster_config.json --versions versions.json --target-kubeconfig <path> --target-kubecontext <context>
Options
-h, --help help for run
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")
--skip-inbound-data skip inbound data migration
--skip-outbound-data skip outbound data migration
--skip-pre-reqs skip prerequisite checks for data migration
--target-context string name of kubeconfig context to use for target cluster
--target-kubeconfig string target cluster kubectl configuration file
--versions string path to versions file
--timeout duration timeout of the command (default 5h0m0s)
