通知を受け取る
UiPath Process Mining
UiPath Process Mining ガイド
UiPath Automation Hub との連携を設定する
はじめに
Different UiPath products work together to discover, investigate and build automation and communicate process improvements. UiPath Automation Hub is used to turn ideas for automation that are discovered from UiPath Process Mining into real automated implementations. If UiPath Process Mining is set up for integration with UiPath Automation Hub it is possible to submit ideas for process improvements that are subject for automation directly from UiPath Process Mining to UiPath Automation Hub.
This page describes how to set up UiPath Process Mining to enable end-users to send automation ideas directly from the Process Graph to UiPath Automation Hub.
Step 1: Generate a Token from UiPath Automation Hub
When generating a token, make sure that you have selected a user in the User field to generate a User Assigned Token. This user will be assigned as the Submitter when sending the automation idea to UiPath Automation Hub.
Follow the steps below to generate your Token from UiPath Automation Hub.
Step
Action
1
Go to UiPath Automation Hub and log in to your account.
2
Go to Admin Console > Platform Setup > Open API.
3
Click on Generate Token.
The Add Token dialog is displayed.
4
Enter a name for the Token in the Token Name field, for example Process mining.
5
Make sure the App Key field is left blank.
6
In the User field, search for the user that will be used as the service account to connect with UiPath Automation Hub.
7
Click on Save.
The new Token is displayed in the list.
8
Click on the Copy to Clipboard icon to copy the Token. It includes both Tenant ID and Token generated. See the illustration below.
Do not set up an App Key, so make sure the App Key field is left blank in the Add Token dialog.
889889
For a detailed description on how to generate your Token from Automation Hub refer to the Automation Hub API guide
Step 2: Adapt the Process Mining Server Settings
To enable end users to send automation ideas you must specify the AutomationHubAppToken setting in the Server Settings.
Follow these steps to adapt the Server Settings.
Step
Action
1
Go to the Settings tab of the Superadmin page of your UiPath Process Mining installation.
4
Enter the following line:
,"AutomationHubAppToken": "<token>",
Note: <token> is the token pasted from the Clipboard. See illustration below for an example.
6
Click on SAVE to save the changes to the Server Settings.
876876
For security reasons, you may not want to display the actual token value in the Server Settings. If you have set up Azure Key Vault for password storage, you can store the actual token in Azure Key Vault and refer to it from the Server Settings.
例: "AutomationHubAppToken": {"credential": "AhAppToken"}
See Use a Credential Store.
Automation Hub on-premises
By default, a connection is set up to Automation Hub in UiPath Automation CloudTM. If you want to connect to an on-premises version of Automation Hub, you must specify the URL to the desired Automation Hub instance in the AutomationHubUrl Server Setting. (See The Settings Tab).
The URL is of the following format:
`https://<fully qualified domain name (fqdn)>///
以下の画像で例をご確認ください。
12801280
Below is a description of the elements of the URL.
Element
The cluster URL as specified during the installation of UiPath Automation Suite.
Note: for a multi-node installation, this is the
DNS hostname or load balancer url. For a single-node installation, this is the DNS hostname or machine domain name.
<organization>/<tenant>/<service>
Similar to Automation CloudTM the URL contains the name of the organization, the tenant name, and the service.
Login redirect (optional)
An optional (API) redirect.
Step 3: Configure the Process Graph for sending automation ideas
If UiPath Process Mining is set up for integration with UiPath Automation Hub the Process Graph must be configured to enable end-users to send ideas for process improvements that are subject for automation directly from the Process Graph to UiPath Automation Hub.
See Configure the Process Graph for Sending Automation Ideas.
関連情報
See Sending Automation Ideas to UiPath Automation Hub.
See Setting up an Azure Key Vault Credential Store.
9 か月前に更新
改善の提案は、API リファレンスのページでは制限されています
改善を提案できるのは Markdown の本文コンテンツのみであり、API 仕様に行うことはできません。
