Configurer une authentification Kerberos avec l’authentification MSSQL de base pour Process Mining
Remarque :
When you are performing a new installation and you want to use Kerberos authentication, it is strongly recommended to configure process app security as single_account. Refer to Configuring process app security for details.
Lorsque vous souhaitez utiliser l’authentification Kerberos pour vous connecter à Automation Suite et utiliser l’authentification MSSQL de base pour Process Mining, vous devez ajouter les éléments suivants dans la section processmining du fichier cluster_config.json.
"kerberos_auth_config": {
      "enabled": false
      "enabled": false
Le code suivant vous fournit un exemple de section processmining avec une authentification Kerberos et une authentification MSSQL de base pour Process Mining.
 "processmining": {
    "enabled": true,
      "enabled": false
    "sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:password%password@servername.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server",
    "warehouse": {
          "sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
          "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:Password%password@servername.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server"
 "processmining": {
    "enabled": true,
      "enabled": false
    "warehouse": {
