OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl version
Print the current client version information.
uipathctl version [flags]uipathctl version [flags]
Options
-h, --help   help for version  -h, --help   help for version
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
