uipathctl reference guide
Last updated Apr 28, 2025
uipathctl service
Manage service-related commands.
uipathctl service [flags]uipathctl service [flags]
Options
 -h, --help   help for service -h, --help   help for service
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
