uipathctl reference guide
Last updated Feb 28, 2026
uipathctl registry validate
Validate the docker registry.
uipathctl registry validate [flags]
Options
  -h, --help              help for validate
      --manifest string   path to docker image manifest
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
