uipathctl reference guide
uipathctl reference documentation
Reference documentation for uipathctl, the command-line tool for controlling the Automation Suite deployment.
Description​
Controls the UiPath® Automation Suite deployment
uipathctl [flags]
uipathctl [flags]
Options​
  -h, --help                help for uipathctl
  • Description​
  • Options​
Connect
Stay updated
