uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config add-host-admin
Add a host admin and specify their credentials.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config add-host-admin [flags]uipathctl config add-host-admin [flags]
Examples
        # Add host admin with the provided username and password in cluster
        uipathctl config add-host-admin --username newadmin --password password
        # Add host admin with the provided username, password and email in cluster
        uipathctl config add-host-admin --username newadmin --email email --password password
        # Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
        uipathctl config add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig        # Add host admin with the provided username and password in cluster
Options
  -e, --email string       host admin email
  -h, --help               help for add-host-admin
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
  -p, --password string    host admin password
  -u, --username string    host admin username  -e, --email string       host admin email
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
