2022.4
Automation Suite インストール ガイド
self-heal-operator および sf-k8-utils リポジトリが見つからない
説明
この問題が発生すると、ワークロードが ImagePullBackOff または ErrImagePull のステートになり、次のエラーが表示されます。
Failed to pull image "sf-k8-utils-rhel:<tag>": rpc error: code = Unknown desc = failed to pull and unpack image "docker.io/library/sf-k8-utils-rhel:<tag>": failed to resolve reference "docker.io/library/sf-k8-utils-rhel:<tag>": failed to do request: Head "https://localhost:30071/v2/library/sf-k8-utils-rhel/manifests/<tag>?ns=docker.io": dial tcp [::1]:30071: connect: connection refused
OR
Failed to pull image "self-heal-operator:<tag>": rpc error: code = Unknown desc = failed to pull and unpack image "docker.io/library/self-heal-operator:<tag>": failed to resolve reference "docker.io/library/self-heal-operator:<tag>": failed to do request: Head "https://localhost:30071/v2/library/self-heal-operator/manifests/<tag>?ns=docker.io": dial tcp [::1]:30071: connect: connection refusedFailed to pull image "sf-k8-utils-rhel:<tag>": rpc error: code = Unknown desc = failed to pull and unpack image "docker.io/library/sf-k8-utils-rhel:<tag>": failed to resolve reference "docker.io/library/sf-k8-utils-rhel:<tag>": failed to do request: Head "https://localhost:30071/v2/library/sf-k8-utils-rhel/manifests/<tag>?ns=docker.io": dial tcp [::1]:30071: connect: connection refused
OR
解決策
この問題を修正するには、以下のスクリプトをクラスター内のすべてのノードから 1 つずつ実行します。
#!/bin/bash
export KUBECONFIG=${KUBECONFIG:-/etc/rancher/rke2/rke2.yaml}
export PATH=$PATH:/var/lib/rancher/rke2/bin:${SCRIPT_DIR}/Fabric_Installer/bin:/usr/local/bin
function get_docker_registry_url() {
  local rancher_registries_file="/etc/rancher/rke2/registries.yaml"
  config=$(cat < ${rancher_registries_file} | grep -A1 "configs:"|tail -n1| awk '{print $0}'|tr -d ' '|tr -d '"')
  url="${config::-1}"
  echo "${url}"
function get_docker_registry_credentials() {
  local key="$1"
  value=$(cat < ${rancher_registries_file} | grep "$key:" | cut -d: -f2 | xargs)
  echo "${value}"
function get_cluster_config() {
  local key=$1
  # the go template if prevents it from printing <no-value> instead of empty strings
  value=$(kubectl get secret service-cluster-configurations \
    -o "go-template={{if index .data \"${key^^}\"}}{{index .data \"${key^^}\"}}{{end}}" \
    -n uipath-infra --ignore-not-found) || true
  echo -n "$(base64 -d <<<"$value")"
function update_image_tag() {
    username=$(get_docker_registry_credentials username)
    password=$(get_docker_registry_credentials password)
    url=$(get_docker_registry_url)
    images=(self-heal-operator sf-k8-utils-rhel)
    for image in ${images[@]}; do
        echo "Start checking available $image tag"
        tag=$(curl -u $username:$password -X GET https://${url}/v2/$image/tags/list -k -q -s | jq -rc .tags[0] )
        if [[ "${tag}" != "null" ]]; then
            echo "$image with tag ${tag} found..."
            podman login ${url} --username $username --password $password --tls-verify=false
            podman pull ${url}/${image}:${tag} --tls-verify=false
            podman tag ${url}/${image}:${tag} ${url}/uipath/${image}:${tag}
            podman tag ${url}/${image}:${tag} ${url}/library/${image}:${tag}
            podman push ${url}/uipath/${image}:${tag} --tls-verify=false
            podman push ${url}/library/${image}:${tag} --tls-verify=false
            echo "$image is retag and push to docker registry"
        else
            echo "no tag available for $image"
        fi
    done
function validate_rke2_registry_config() {
  local endpoint_present="false"
  endpoint=$(cat < ${rancher_registries_file} | grep -A2 "docker.io:" | grep -A1 "endpoint:"|tail -n1|xargs)
  if [[ -n "${endpoint}" ]]; then
    endpoint_present="true"
  fi
  echo "${endpoint_present}"
function update_rke2_registry_config() {
   local DOCKER_REGISTRY_URL=$(get_docker_registry_url)
   local DOCKER_REGISTRY_LOCAL_USERNAME=$(get_docker_registry_credentials username)
   local DOCKER_REGISTRY_LOCAL_PASSWORD=$(get_docker_registry_credentials password)
   local registriesPath="/etc/rancher/rke2/registries.yaml"
   local DOCKER_REGISTRY_NODEPORT=30071
   echo "Create temp file with name ${registriesPath}_tmp"
   cp -r ${registriesPath} ${registriesPath}_tmp
   echo "Start updating ${registriesPath}"
   cat > "${registriesPath}" <<EOF
mirrors:
  docker-registry.docker-registry.svc.cluster.local:5000:
    endpoint:
      - "https://${DOCKER_REGISTRY_URL}"
  docker.io:
    endpoint:
  ${DOCKER_REGISTRY_URL}:
    endpoint:
configs:
  "localhost:${DOCKER_REGISTRY_NODEPORT}":
    tls:
      insecure_skip_verify: true
    auth:
      username: ${DOCKER_REGISTRY_LOCAL_USERNAME}
      password: ${DOCKER_REGISTRY_LOCAL_PASSWORD}
EOF
function is_server_node() {
    [[ "$(systemctl is-enabled rke2-server 2>>/dev/null)" == "enabled" ]] && echo -n "true" && return
    echo "false"
function main() {
    local is_server_node=$(is_server_node)
    local install_type=$(get_cluster_config "INSTALL_TYPE")
    if [[ "${install_type}" != "offline" ]]; then
        echo "This script is compatible with only offline cluster. Current cluster install_type=${install_type}"
        exit 0
    fi
    if [[ "${is_server_node}" == "true" ]]; then
        echo "current node is identified as server node. Updating image tag"
        update_image_tag
    else
        echo "current node is identified as agent node."
    fi
    rke2_registry_config_is_valid=$(validate_rke2_registry_config)
    if [[ "${rke2_registry_config_is_valid}" == "false" ]]; then
      echo "start updating rke2 config"
        echo "Registry configuration is updated. Restarting service using command: systemctl restart rke2-server"
        systemctl restart rke2-server.service
      else
        echo "Registry configuration is updated. Restarting service using command: systemctl restart rke2-agent"
        systemctl restart rke2-agent.service
      fi
    else
      echo "rke2 config update is not required"
    fi
main#!/bin/bash
  url="${config::-1}"
  echo "${url}"
  local key="$1"
  echo "${value}"
  local key=$1
        else
        fi
    done
  fi
mirrors:
    endpoint:
  docker.io:
    endpoint:
    endpoint:
configs:
    tls:
    auth:
EOF
    echo "false"
function main() {
        exit 0
    fi
        update_image_tag
    else
    fi
      else
      fi
    else
    fi
main
注:
fix_image_project_id.sh スクリプトは、Kubernetes サーバー (rke2 サービス) と、ノードで実行されているすべてのワークロードを再起動します。
fix_image_project_id.sh スクリプトの実行が必要になるのは、Automation Suite 2021.10.0、2021.10.1、2021.10.2、2021.10.3、または 2021.10.4 を使用する場合のみです。
  • 説明
  • 解決策
接続
ヘルプ リソース サポート
学習する UiPath アカデミー
質問する UiPath フォーラム
最新情報を取得
