Redimensionner le PVC
Redimensionner le PVC objectstore​
Resizing the PVC is required only if you upgraded to Automation Suite 2022.10 and did not migrate your Objectstore to raw disks.
Pour afficher plus d'informations sur Objectstore, exécutez la commande suivante :
sudo ./configureUiPathAS.sh objectstore --help
Sortie
Manage objectstore configuration
Usage:
  configureUiPathAS.sh objectstore [command]
  configureUiPathAS.sh objectstore [flags]
Available Commands:
  resize-pvc                          Resize PVC
Flags:
  -h|--help                           Display help
Usage:
Available Commands:
Flags:
Remarque :
PVC resize can be dangerous and will result in downtime of entire or few of the effect components of cluster. Take caution before performing this operation.
Pour afficher plus d'informations sur le redimensionnement de l'Objectstore PVC, exécutez la commande suivante :
sudo ./configureUiPathAS.sh objectstore resize-pvc --help
La commande renvoie la sortie suivante :
Resize PVC provided by different CSI drivers
Arguments
  -s|--size            [Required] : Size of PVC. Allowed formats are
                       - Plain integer
                       - A fixed-point number using one of these suffixes: E, P, T, G, M, k
                       - A fixed-point number using one of power-of-two equivalents suffixes: Ei, Pi, Ti, Gi, Mi, Ki
  -b|--sub-component   [Required] : Sub-component to resize. Possible Values [mon|data]
  -d|--debug           Increase logging verbosity to show all debug logs
  -h|--help            Show this help message and exit
  -f|--force           Allow deletion of pods to resize the PVC. This may cause downtime
Examples
  Update PVC size for objectstore mon to 105 Gi
  configureUiPathAS.sh objectstore resize-pvc --size 105Gi  --sub-component "mon"
Arguments
                       - Plain integer
Examples
Pour redimensionner le stockage de données de ceph objectstore, exécutez la commande suivante :
sudo ./configureUiPathAS.sh objectstore resize-pvc --size 1024Gi --sub-component data
La commande redimensionne le PVC de stockage de données à 1 Tio.
Avant de commencer l'opération de redimensionnement du PVC, l'outil vous avertit de l'impact. Vous devez accepter pour pouvoir continuer. Vous pouvez également utiliser l'indicateur --force pour ignorer l'avertissement.
Remarque :
If the attempt to resize the objstore pvc operation failed, see the Troubleshooting section for a fix.
Redimensionner le PVC rabbitmq​
Pour afficher plus d'informations sur le redimensionnement du PVC rabbitmq, exécutez la commande suivante :
sudo ./configureUiPathAS.sh  rabbitmq resize-pvc --help
Arguments
                       - Plain integer
  -b|--sub-component   [Required] : Sub-component to resize. Possible Values [server]
Examples
  Update PVC size for rabbitmq server to 105 Gi
  configureUiPathAS.sh rabbitmq resize-pvc --size 105Gi  --sub-component "server"
Arguments
                       - Plain integer
Examples
Pour redimensionner le PVC rabbitmq, exécutez la commande suivante :
sudo ./configureUiPathAS.sh rabbitmq resize-pvc --size 100Gi  --sub-component "server"
Redimensionner le PVC mongodb​
Pour afficher plus d'informations sur le redimensionnement du PVC mongodb, exécutez la commande suivante :
sudo ./configureUiPathAS.sh  mongodb resize-pvc --help
Arguments
                       - Plain integer
  -b|--sub-component   [Required] : Sub-component to resize. Possible Values [data|logs]
Examples
  Update PVC size for mongodb data to 105 Gi
  configureUiPathAS.sh mongodb resize-pvc --size 105Gi  --sub-component "data"
Arguments
                       - Plain integer
Examples
Pour redimensionner le PVC mongodb, exécutez la commande suivante :
sudo ./configureUiPathAS.sh mongodb resize-pvc --size 105Gi  --sub-component "data"
La commande redimensionne le PVC de données de mongodb. Si vous souhaitez redimensionner le pvc logs, vous devez utiliser --sub-component "logs".
Redimensionner le PVC de surveillance​
Pour afficher davantage d'informations sur le redimensionnement du PVC de surveillance, exécutez la commande suivante :
sudo ./configureUiPathAS.sh monitoring resize-pvc --help
Arguments
                       - Plain integer
  -b|--sub-component   [Required] : Sub-component to resize. Possible Values [alertmanager|prometheus]
Examples
  Update PVC size for monitoring alertmanager to 105 Gi
  configureUiPathAS.sh monitoring resize-pvc --size 105Gi  --sub-component "alertmanager"
Arguments
                       - Plain integer
Examples
Pour redimensionner le PVC de surveillance, exécutez la commande suivante :
sudo ./configureUiPathAS.sh monitoring resize-pvc --size 100Gi  --sub-component "alertmanager"
Vous pouvez redimensionner le PVC prometheus en transmettant la valeur prometheus à l’argument --sub-component.
Redimensionner le PVC du registre​
Pour afficher plus d'informations sur le redimensionnement du PVC du registre, exécutez la commande suivante :
sudo ./configureUiPathAS.sh registry resize-pvc --help
Arguments
                       - Plain integer
  -b|--sub-component   [Required] : Sub-component to resize. Possible Values [data]
Examples
  Update PVC size for registry data to 105 Gi
  configureUiPathAS.sh registry resize-pvc --size 105Gi  --sub-component "data"
Arguments
                       - Plain integer
Examples
Pour redimensionner le PVC du registre, exécutez la commande suivante :
sudo ./configureUiPathAS.sh registry resize-pvc --size 100Gi  --sub-component "data"
