Process Mining
- Release notes
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- App templates
- Additional resources
- Editing data transformations in a local environment
- Designing an event log
- Extending the SAP Ariba extraction tool
- Performance characteristics
- Basic troubleshooting guide
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&q=100)
Process Mining
Last updated 27. Juni 2024
2023.10.4
If you use Amazon S3 storage objects and you want to prevent uploading data using a pre-signed URL, this is now handled via
the global
disable_presigned_url
flag.
Refer to Pre-signed URL configuration in the Automation Suite guide for more information.
We now support CData Sync 2024 - 24.1.8885 for Loading data using CData Sync.
We are constantly working to improve your UiPath® Process Mining experience. Even though there are no major significant changes with this release, we made sure to bring security and accessibility improvements as well as minor bug fixes to our product.
